We have a slurry phase supply line which has a control valve. We are flushing it with pure water at control valve upstream and downstream to avoid any sort of blockage/chocking of particles in the control valve.
We know the line size and the process side slurry flowrate. We need to caculate the amount of water required for flushing.
Hence we require some sort of basis for calculation of flushing medium flowrate.
Firoz/Manoj
Control Valve In Slurry Phase
Started by Firoz Raja, Jul 27 2007 12:16 AM
No replies to this topic
Posted 27 July 2007 - 12:16 AM
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
Three Phase Seperator ModificationStarted by Guest_halkeshhulk_* , 10 Jun 2025 |
