Heat Exchanger Pinch Temperature
Posted 23 September 2007 - 10:44 PM
I'm a bit embarrassed to ask...Im not sure I fully understand the definition of the term "pinch temperature" when dealing with heat exchangers. I used the resources I have and the search engines but still don't feel like 100% understand. Is it the closest temperature between the cold and hot curves? or is this the internal pinch temperature?
Your help is greatly appreciated.
Posted 24 September 2007 - 08:44 AM
Posted 26 May 2010 - 01:39 AM
But this is not practically possible as it would require an infinite surface to do this....hence the closest temperature is what is seeked....so u may get a hot end pinch when cold fluid is heated to the inlet temp of hot fluid...or a cold end pinch when hot fluid is cooled to the cold fluid inlet temperature...
Posted 24 March 2011 - 10:22 AM
I know this thread is old, but I still hope anyone has something to add
To add more..i would like to say with reference to heat exchanger effectiveness...for a heat exchanger the maximum heat transfer is said to have taken place when the fluid of minimum heat capacity(could be the hot or cold fluid)is heated(or cooled)to the inlet temperature of the other fluid....(i hope its clear that am talkin for a counterflow Hx)
