hello,
I am working on a chemical process which hopefully results in SiCl4 as a byproduct. I have been unable to find a way to convert SiCl4 to SiO2 (silica) and Cl2 or HCl for recycle back into the reaction process. The only think I have found is SiCl4 + H2O = H2SiO4 + 4HCl. Is there a way to convert H2SiO4 to SiO2 and H2O? Any suggestions or leads would be helpful.
Thanks,
How To Oxidize Silicon Tetrachloride (sicl4) To Silicon Dioxide (sio2)
Started by sandman, Oct 02 2007 02:09 AM
No replies to this topic
Posted 02 October 2007 - 02:09 AM
Posted 05 October 2007 - 01:40 PM
QUOTE (sandman @ Oct 2 2007, 02:09 AM) <{POST_SNAPBACK}>
hello,
Thanks,
Thanks,
The only method that I know and is done in a laboratory is:
SiCl4 (gas) + O2 -> SiO2 (solid) + 2Cl2 (in the presence of heat)
Posted 05 October 2007 - 01:49 PM
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
![]() How Is The Dry Process Using Porous Silicon?Started by Guest_LUFER_* , 14 Feb 2023 |
Porous Silicon SimulatorStarted by Guest_LUFER_* , 09 May 2021 |
![]() Porous Silicon: High Internal Surface Area Of The Psi Surface Which PeStarted by Guest_LUFER_* , 11 Mar 2021 |
Porous Silicon: StabilityStarted by Guest_LUFER_* , 09 Mar 2021 |
