Note-4 of the above mentioned topic says 'The head-capacity curve at 100% speed shall extend to at least 115% of the capacity of the CRP'.
Will anybody explain as to what this term 'extend to' means?
Thanks in advance.
Urgent Question :api 617, Centrifugal Compressor Guidelines Question.
Started by omnibus, Oct 05 2007 04:02 PM
Posted 05 October 2007 - 04:02 PM
Posted 07 October 2007 - 11:12 AM
BUMP, BUMP, BUMPITY BUMP.
Posted 08 October 2007 - 04:27 PM
If I knew what CRP was, I might be able to help.
Posted 09 October 2007 - 06:39 AM
As per API 617, 7th Edition, July 2002:
Note 4 on Figure 2.1-1a – Illustration of Terms reads in its entirety as follows:
“The head-capacity curve at 100% speed shall extend to at least 115% of the capacity of the CRP. Head-capacity curves at other speeds shall be extended to equivalent capacity at each speed. For example, the head-capacity curve at 105% speed shall be extended to at least 1.05 times 1.15 times the capacity of the CRP; the head-capacity curve at 90% speed shall be extended at least 0.9 times 1.15 times capacity of the CRP; and so on. These points define the ‘approximate capacity limit’ curve.”
In the previous Note 3, CRP is defined as “Compressor Rated Point”.
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
Centriugal CompressorStarted by Guest_Rahimzadeh_* , 02 Mar 2025 |
Pulsation Device In Reciprocating CompressorStarted by Guest_zaidanamir_* , 17 Feb 2025 |
