hello.i really need help o my plant design project.i need to recover methanol from a feed that has a lot of components. methyl ester, triglyceride,glycerol, soap,water and other components. is flash distillation a possible solution? i've tried designing a flash drum but i had a problem on finding the data of my components.can you help me?
Methanol Recovery
Started by kayciemae, Oct 11 2007 10:37 AM
Posted 11 October 2007 - 10:37 AM
Posted 11 October 2007 - 10:56 AM
Dear
Please don't repeat same problem in different forums and make the members confuse.Bacause
everywhere you will get the same reply.This is really wonderful that you want to design a plant and
you don't have an idea regarding the basic properties of the components you are going to handle.
Padmakar Katre
Padmakar Katre
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
