Hi.
I need kalium.carbonate as a component in HYSYS, but i cant find it. I probably need to add it as a hypothetical component, but I cant figure it out. I need it for simulation of a CO2 capture plant. Can anyone help me? Thanks
Calcium Carbonate (potassium Carbonate) In Hysys
Started by zebu, Oct 15 2007 06:14 AM
Posted 15 October 2007 - 06:14 AM
Posted 15 October 2007 - 11:00 AM
Dear Zebu,
If I am not wrong you are working with a MEG plant and you are going to remove the CO2 (which is the ethylene oxidation product).A long back I was stucked with the same problem when I was doing these simulation.You have to define pottacium carbonate and bi-carbonate as hypothetical components.
Padmakar Katre
Padmakar Katre
Posted 15 October 2007 - 05:23 PM
hi mr Padmakar S Katre
if u want a simplified PFD for pottacium carbonate wich used to remove CO2
i have it in details
Posted 16 October 2007 - 08:15 AM
Dear,
I will be thankful if I will recieve the same.My mail id is pady_chem_iisc@inbox.com
Thanks in advance,
Padmakar Katre
Thanks in advance,
Padmakar Katre
Posted 22 October 2007 - 03:31 AM
hi mr Padmakar Katre
sorry i have it as a hard copy
and it can't be scanned
cause paper size is A3 and my scanner is A4
so if u have a specific quistion ask and i will answer u
Posted 22 October 2007 - 11:12 AM
Dear,
I will suggest you how to tackle this problem.Get the photocopy of the A3 Size paper to A4 (by reducing the photocopy size-a feature of your photocopy machine) which is quite easy and then get it scanned and send it to me if you wish to send it and if you find the way I told is easier otherwise leave it.Anyways thanks for your concern.
Padmakar Katre
Padmakar Katre
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
