hi to all
i,m using hysys
i,m about designing a reactor and distillation column
i want to plot a variavles to have data on chart
i see critical points
for example i want to see the effect of reactor length of product composition
how can i do that on hysys
i want to know how to do it with hysys
and thank u all
Ploting Variables In Hysys
Started by We R One, Oct 22 2007 03:36 AM
Posted 22 October 2007 - 03:36 AM
Posted 22 October 2007 - 09:31 AM
Could you please try to write proper English, with proper punctuation and capitalization, so that it is easier to understand what you mean?
In Hysys you can set up a case study to accomplish what you want. The case study feature is accessed via Tools/Databook. I would recommend that you read the appropriate section in the User Guide first, and then come back with specific questions.
Once you have a table of your results, you can plot the data using Hysys, but I usually find it easier to copy everything into Excel and format and plot the data there.
