Dew Point Temperature In Exhaust
Started by vikber09, Nov 06 2007 08:18 AM
7 replies to this topic
Posted 06 November 2007 - 08:18 AM
Hi!
I have calculated the dew pint temeprature of water vapor in exhaust from a diesel engine using a simple combustion reaction. With ideal gas relation I have calcualted the partial pressure of the water vaporu int the exhaust and then used it in the following formula:
Ps=e^(12,03-4025/(Tdew+235))
and solved the Tdew temperature from that.
What I wonder is if the constants in this equation not are applicable for exhaust or only for humid air?
(I know there is a small change in molecular weight of exhaust and air)
Posted 08 November 2007 - 05:10 AM
I think that this relationship is not valid for diesel exhaust. You want the ACID dew point
The reason is that the fuel contains sulfur, and that what you need is an acid dew point.
Is is also possible, if the diesel uses heavy fuel oil, that you have Vanadium. vanadium would promote SO2 to SO3 conversion, much lowering the acid dew point.
You need
The water content and the SO3 concentration (and to a lesser extent SO2)
You need
Posted 08 November 2007 - 12:36 PM
vikber09:
take a look to this site http://" target="_blank">http://www.hrsgdesign0.htm → Process → Acid Dew Point of flue gas.
Good luck !
Good luck !
Posted 08 November 2007 - 08:52 PM
QUOTE (ELEMAN @ Nov 8 2007, 12:36 PM) <{POST_SNAPBACK}>
vikber09:
take a look to this site http://<a%20href=" target="_blank">http://www.hrsgdesign0.htm</a> → Process → Acid Dew Point of flue gas.
Good luck !
Good luck !
Link problem...
I guess ELEMAN has proposed Acid Dew Point Of Flue Gas.
JoeWong
Posted 09 November 2007 - 07:52 AM
Hello everybody:
You are quite right JoeWong, thank you.
Posted 19 November 2007 - 06:06 PM
Hi there:
Here is an MS Excel file that deals with ideal and complete combustion of coal and oil type fuel.
http://engware.i-den.../combustion.xls
For stoichiometry values => 1, it will provide one with the flame temperature and combustion products composition on weight and mole basis. By knowing the H2O volume fraction, one can find out its partial pressure and see what the dew temperature value could be.
I thought that this might be of some help when dealing with the subject matter.
Thanks,
Gordan
Thanks,
Gordan
Posted 21 November 2007 - 08:27 AM
Hello everybody:
engware: this workbook is valuable, thanks for share it with us in the Forum.
Posted 21 November 2007 - 08:51 AM
ELEMAN:
I am glad to be of some help to you and others at Cheresources.com and be able to share some of my work with those interested.
Thanks,
Gordan
Thanks,
Gordan
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
