Posted 13 November 2007 - 08:23 PM
Roopa:
I had to study the photos well to find what I believe is the impeller failure you indicate. I believe the impeller failed by having its “nose” (the cylindrical extension of its inlet eye) sheared or cut off. The portion that was cut off is the thin cylinder or ring that we can see being propped up to where it was originally joined to the impeller eye and we also can see it laying on the table as the impeller is being extracted. Am I correct? If not, please describe the nature of the failure.
If I am correct, then it is a mechanical failure that can be caused by one of several factors:
The impeller could have been vibrating or “wobbling” on the shaft due to a mechanical failure such as a worn or damaged bearing or it could have suffered repeated process shocks such as those from continued cavitation. The inlet to the impeller wasn’t cut off by the cavitation (if it was cavitation); the cavitation could have caused traumatic and repeated vibration of the impeller, causing it to rub against a harder casing surface that “machined” or cut off the separated piece. We really are just guessing at this point because although your pictures are great shots and have excellent focusing and detail, we still lack a lot of other details. We don’t know the condition or results of the front casing. We also don’t know about the process conditions (temperatures, pressures, vibrations, noises, etc.) prior to the failure – and for how long. You say you are injecting steam to heat the 100 oF water being pumped but you don’t give use a drawing or sketch showing where, exactly, this injection takes place and how long this pump has work successfully – if at all.
The impeller seems to be made of cast iron. Depending on the grade of the cast iron, it could be mild and soft material instead of meehanite or close-grained, which would make it susceptible to being machined off with a different, tougher metal.
Yes, steam hammering in the discharge pipe could be causing impeller vibration in this type of cantilevered impeller design. However, the hammering doesn’t cause the impeller to be cut off directly. It may be causing impeller deflection due to the constant hammering in the line. If so, how close is the hammering source? Can it be placed further away from the impeller? Is one or two check valves placed between the hammering source and the pump’s discharge port? What make and model of pump is it?
Can you furnish a sketch of the set up and the piping on an Excel spreadsheet?
