I am designing an Acrylonitrile plant facility with help of my team. I am responsible for designing the front-end which include feedstock storage and handling and production of the desired products and the rest of the team are responsible for purification, waste treatment and further utilities. I have several issues and would like you to give me your technical advice, which will be highly appreciated.
A- One of the technical obstacles I am encountring is storing propylene in liquid form. The idea is to pump liquified propylene from tanker to an onsite liquified propylene storage tanks and preheating or vaporize the propylene before injecting the propylene to the reactor. My questions are;
1- What are the usual pumping conditions for liquified Propylene through pipelines and what are the storage conditions for liquified propylene in a given storage tank.
2- How can I decide the amount of refrigerant required to maintain the storage conditions of liquified propylene?
3- The proposed feed conditions of propylene to the reactor is 25oC and 2 atm. Is it advantageous to use a vaporizor over a preheater? If yes, how do vaporizors work?
B- I have a huge amount of Air to be supplied to the Ammoxidation reactor, which is approximately 181,000 m3/hr. I am heating the air from ambient conditions to approximately 200 oC by steam generated from the reactor at 600 psig. My questions are;
1- Is it possible to heat the air using steam in an air heater?
2- What is the best approach for such a process?
3- a) Before entrainment of the air to the heater, the air is filtered. To pump the air into the heater, shall I use a blower or an air compressor?
Sorry for the long questions, but your feedback will impact my final year design. I am in the PFD stage and trying to select the proper equipments to do the job.
Thank you
AHmed Al-Amry
