Dear all:
My client enquire whether acetic acid and acetone can be scrubbed together? As far as I know, acetic acid is usually scrubbed by NaOH solution, acetone can be scrubbed by water (I have no experience on acetone). It seems not a good idea to scrub them together.
Can I have any comments and suggestions on this?
Thanks so much in advance.
PS. This is the my first question in this forum. I hope to have some response.
Acetic Acid And Acetone Scrubber
Started by Felix Wang, Dec 18 2007 04:10 AM
Posted 18 December 2007 - 04:10 AM
Posted 18 December 2007 - 12:03 PM
Dear,
What is concentraion of NaOH?As well as the acatic acid and acetone concentration in the gas stream and flowrates (both liquid and the gas streams) and the terminal condition(P,T)? Please give details of the problem so that we can suggest you some useful idea.
Waiting for your reply.
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
