I need to select compressors and air dryers for the following requirements:
1. 1000 nm3/hr at 9 bar
2. 7000 nm3/hr at 12 bar
3. 3250 nm3/hr at 15 bar
What will be the best combination of compressors for the above presssures? Can I opt three compressors for three different pressures or can I go for two compressors - one at 12 bar and reduce pressure to 9 bar and one at 15 bar?
What will be the best combination of compressor and dryer?
D. Ramkumar
Air Compressor Selection
Started by Ramkumar, Dec 26 2007 01:01 AM
Posted 26 December 2007 - 01:01 AM
Posted 26 December 2007 - 07:27 AM
Ramkumar:
What you furnish is totally insufficient information. An engineer cannot respond to the questions you ask without knowing (at the very least):
- The type, identification, and full description of the process they will be feeding and its sensitivities with regards to contamination, flow variation, pulsations, and turn-downs in capacity;
- The type of air compressor – dynamic or prositive displacement – and its driver;
- The type of operation of the process – batch or 24 hours/day – 7 days/week.
Even without knowing anything about your process or the application, I would not follow the train of thought you seem to be seeking: using one, 11,250 nm3/hr compressor at 15 bar(g) discharge and distributing the lower pressure supplies from each stage. I have never seen this done, but that doesn’t mean it can’t be done – if the economic incentives are sufficient. I would not seek anyone’s opinion or recommendation on this idea without consulting directly with compressor manufacturers. Anyone else’s opinion is a waste of time, in my opinion.
Posted 27 December 2007 - 07:55 AM
3 pressure level with demand on each level can generate many combinations...
In addition to the list by Mr. Montemayor :
4) are the indicated flow continuous, intermittent or peak ?
5) if they are continuous flowrate, what are the peak flow and how long is the demand of peak flow ?
6) what's the strategy on the buffer volume ? Large buffer to cater for intermittent peak or small buffer with large compressor ?
7) Dedicated buffer for each level ?
8) what sparing philosophy should be followed ?
Answers to these questions may lead you to some good combination......
Posted 08 April 2009 - 09:29 AM
The nature of your question is not same as the original post. Suggest you to open a post...
Posted 08 April 2009 - 04:29 PM
Thanks for your warning. I made a new thread. FYI, it is a commercial practice, so I put it under Chemical Professional.
Posted 03 January 2012 - 07:54 PM
Hi, I have a 88 cubic feet receiving tank and 386 cubic feet vessel, what is the capacity (scfm) of an air compressor do I need to buy for the best suitable for these volumes.
Pressurization to these two volume is 10psi/min.
And final pressure is 150 psi.
Thanks,
Thanks,
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Centriugal CompressorStarted by Guest_Rahimzadeh_* , 02 Mar 2025 |
