What are the advantages of " Pilot Operated Safety Relief valve" over normal " Safety relief valve" ? Are there any disadvantages of POSRV ?
Pilot Operated Safety Relief Valve
Started by ayan_dg, Jan 04 2008 11:12 AM
Posted 04 January 2008 - 11:12 AM
Posted 04 January 2008 - 11:18 AM
Here is a good description of the differences in safety valve types:
http://www.spiraxsar...afety-valve.asp
Posted 04 January 2008 - 12:12 PM
Here is another good reference, Crosby's PSV engineering handbook:
http://www.tycoflowc...OMC-0296-US.pdf
Posted 05 January 2008 - 02:12 AM
QUOTE (ayan_dg @ Jan 4 2008, 11:12 AM) <{POST_SNAPBACK}>
Advantages
- Relieving pressure not affected by backpressure
- Can operate at up to 98% of set pressure
- Less susceptible to chatter (some models)
Please also read " Why use a pilot valve ? "
Disadvantages
- Pilot is susceptible to plugging
- Limited chemical and high temperature use by “O-ring” seals
- Vapor condensation and liquid accumulation above the piston may cause problems
- Potential for back flow
Another comprehensive comparison...Advantages and Limitations of Valve Types - Valve Type Comparison
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
