i want to ask this question it already annoying me why co2 when expanding through membrane in aprocess like sweetening of natural gas by membrane not cooled according joule_thomson effect actually it cooled but not to much it drop from 50c to 40c when expand from 60 bar to 1.5 bar!!!!!!
can i get answer
Why Co2 When Expanding Through Membrane Not Cooled?
Started by mido, Jan 22 2008 07:22 AM
Posted 22 January 2008 - 07:22 AM
Posted 22 January 2008 - 08:01 AM
Are the adiabatic contitions (or close to adiabatic) maintained in this process?
Joule-Thompson effect refers to rapid expansion and it is defined for adiabatic process... This can be an issue, but it is only my guess...
Posted 22 January 2008 - 11:16 PM
A quick run on HYSYS telles me the temperature drops from 50°C to -20°C for an isoenthalpic pressure drop of 60 bar.
Rajiv
Rajiv
Posted 23 January 2008 - 09:40 AM
I am not 100% sure about this one, but I will give a try...
If I remember well, for each compound there is a curve called "inversion curve" which defines the effect of temperature change in case the pressure is increased or decreased. It means that above certain temperature, Joule-Thomson coefficient has a positive value and expansion does not lead to a temperature drop.
It was a long time when I was studying this effect... I think you can find many references @ Perry's or GPSA books, amongst others.
Air-Cooled Condenser Symmetrical Inlet-OutletStarted by Guest_tdeb_* , 06 Nov 2023 |
Air Cooled Heat ExchangerStarted by Guest_memad_* , 13 Sep 2021 |
Membrane SeperationStarted by Guest_huff76_* , 16 Jul 2020 |
Outside Film Coefficients Of Air-Cooled Heat ExchangersStarted by Guest_Nikolay__* , 01 Aug 2019 |
Sizing Pervaporation Membrane Area?Started by Guest_chemeng2014_* , 17 Mar 2019 |
