Currently working on consequence analysis for oil and gas facility. I need to find a jet fire duration, can anybody help me out, i need to know the method to calculate duration or any reference from where i can take this information.
Reply ASAP
Jet Fire Duration
Started by nils, Mar 08 2008 05:08 AM
Posted 08 March 2008 - 05:08 AM
Posted 17 April 2008 - 08:11 AM
QUOTE (nils @ Mar 8 2008, 11:08 AM) <{POST_SNAPBACK}>
Reply ASAP
Reply ASAP
Hi Nils,
let me know whether are you using any softwares to do dispersion calculations. It is normal practice distance traveled by SElected Jet fire Radaiation divided by release rate ( giving no credit to atmospheric conditions., like wind speed, direction of release , pasquil stability critearia , relative humdity, layout resistance ( due to congestion)) Or if you running FRED , you get jet fire time . Normally the duartion will be seconds.
Hope this will provide some guidance ,
You may send me email to vnvemuri@marathonoil.com for any more queries.
Goodlluck
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
![]() Fire Case Gas Expansion (Gas Filled & No Liquid)Started by Guest_moosa.akbar_* , 27 Aug 2024 |
