Hello members,
Has anyone got experience on simulating the ethylene process (ethane feed) using HYSYS or Aspen? I would appreciate a sample file in either simulator. I am particularly interested in the steam cracker and the process reactions therein. Realiastically how many reactions in the complex scheme can be added and make the simulation reasonable? What are typical cracking furnace exit compositions?
Cheers mates
Ethylene Process
Started by Ronflade, Mar 22 2008 08:24 AM
Posted 22 March 2008 - 08:24 AM
Posted 22 March 2008 - 08:51 AM
Modeling complex chemical reactions in HYSYS or AspenPlus with high level of accuracy, required for industrial plants, has never been considered as practical and/or feasible. And, in my opinion, it is definitely something no one of us wants to play with. Highly specialized industrial software has to be used instead, with built-in moduls of different reactors and with a possibility to calibrate your system based on actual plant performance.
I'd suggest you to look for KBC's product: Petro-SIM, which offers built-in moduls of various refinery and petrochemical reaction systems: CCR, FCC, HDS, Alkylation, Coker, Visbreaker, Steam Reformer etc. These models can be calibrated in extremely detailed way using Excel-based (VB) environment. Flowsheeter in Petro-SIM is actually HYSYS, with addition that - apart from standard unit operations - there are models (incorporated) of several industrial plants. I had an opportunity to use it, and I remember it was an excellent tool.
http://www.petro-sim.com/index.htm
http://www.petro-sim...s/Petro-SIM.pdf
Best regards,
Best regards,
Posted 07 May 2008 - 05:37 PM
For Ethyle plant simulation Technip has developed a sotware "SPYRO". It is a ready made software for cracking furnaces.
[Research Request] Uc Berkeley Student Seeking Process Engineers For 1Started by Guest_SangyunKim_* , 10 Jul 2025 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
Ethylene PlantsStarted by Guest_panoska_* , 08 Oct 2024 |
