It was great to read all the posts so far.
We have an application for Non-Lube Instrument Air compressor to be supplied in accordance with API-618.
Solution is a two stage compressor with Adiabatic discharge temperatures of 159 Deg C at each stage.Piston speed restricted to 3.5 m/s. PPS/PTFE wear rings are supplied.
In case API-618 is to be complied with , we may have to go for a three-stager, which means additional cost (beyond our budget)
Could some one help me with arguments in favour of the two-stager(discharge temperature being the key issue) ???this would help lift the project out of the doldrums.
Thanks in anticipation
Ragesh
