Could you help me to evaluate a vapor quantity (concentration ) above hot water at 87 0C ( in open channel).? Water flow rate is 1700 ton/hr.
Thanks in advance
bmicky
Hot Water Vapour Pressure
Started by Guest_bmicky_*, Mar 11 2004 07:58 AM
Guest_bmicky_*
Posted 11 March 2004 - 07:58 AM
Posted 11 March 2004 - 12:54 PM
Here's a link that was posted recently: http://webbook.nist....hemistry/fluid/ This link contains a program that will caclulate the vapor pressure of pure water at 87 C.
Posted 12 March 2004 - 11:39 AM
At 87°C , atmospheric pressure, you would have about 61.7% volume water.
I do not know what you want to do with this information. if the purpose is to calculate water evaporation losses, you would have limitations due to mass and heat transfer.
I would estmate evaporation rate in the range of 15-30 kilos/hour per sqm of free water surface.
If the above gas phase is renewed at a high rate (implying significant gas velocities above the surface), could be more than that
