I've been tryin to figure out how to design a Feed Surge Drum. I took note of DJack77494 comments on a similar question like this back in Nov 2005. However since I require a detailed design of this drum and I have little knowledge on how to approach it, I've been looking everywhere for data. I tried to size it as a Fractionator Reflux Drum (from McKetta) but I believe I can't use my inlet streams as Reflux and Overhead streams. So this seemed to be no help.
In "Rules of Thumbs for Chemical Engineers" I saw they have calculations for Vapor/Liquid Vertical Drum or Horizontal Drum. I don't know if this approach is a good way to go. I did the Vertical Drum calculation but was not quite sure where I was going with this since i assumed a (design time to fill of 10 min.) and using my liquid volumetric flowrate I found the volume to be 1.9 m3. The problem with this was that I have a very small amount of vapour in the form of Acetone goin into the drum and not sure if the volume of the drum took the vapour into consideration.
So Basically I am very confused on how to approach this and where to get my design equations for this type of drum. Most design equations i find are for Reflux Drums.
I attached an excel sheet showing a layout of my process streams into and out of my surge drum. Because of the temperature of the streams, the Acetone is in a vapour state but is a extremely small amount, so not sure how much this affects my drum volume.
I am just asking please if anyone can tell me where and what type of design equations I should use for my vessel and if I am on the right path or not ?.
Nick
