Pump Suction Vs Discharge Line
#1 ayan_dg
ayan_dg
  • 148 posts
Posted 15 April 2008 - 11:54 AM
Why pump discharge line size is kept one standard size smaller than pump suction line ? If it is equal what's the problem ?
Posted 15 April 2008 - 12:30 PM
Ayan:
You are looking at the pump dimensions backwards. Try looking at them with the argument: "The pump SUCTION line size is kept one standard size larger than the pump DISHARGE line in order to avoid suction NPSH and suction problems. There is no problem."
This response is analagous to the ancient saying, "The glass is not half-empty; it is half-full". Besides, there is nothing that anyone outside the pump manufacturers can do about it. Until we all start to fabricate our own pumps, there is nothing that will be done about this pump feature.
#3 djack77494
djack77494
  • 1,282 posts
Posted 15 April 2008 - 04:20 PM
QUOTE (Art Montemayor @ Apr 15 2008, 09:30 AM) <{POST_SNAPBACK}>
Expanding on Art's input slightly, the criteria for sizing pump suction lines is always more conservative, in terms of lesser acceptable velocities and pressure drops, than those of pump discharge lines. Pump suctions can be particular, wanting well developed flow and pressures well in excess of the liquid's vapor pressure. The discharges seem to be more forgiving.
May your glass be more than half full,
Doug
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 16 April 2008 - 10:36 AM
Look at NORSOK standard, page 17-19 (it is also availiable online, but I can't remember where) and things will be more clear. In the case that excellent replies from Doug and Mr Montemayor didn't make you feel confident enough.
[attachment=834:NORSOK_P...s_Design.pdf]
Best regards,
#5 ayan_dg
ayan_dg
  • 148 posts
Posted 17 April 2008 - 06:45 AM
Thanks all for your valuable inputs.
