Posted 21 April 2008 - 11:44 AM
Jiten:
I don't know what you mean by "dealing with". I am going to assume you are at the the design or feasibility stage of design and that you are contemplating saving some capital money by investing in only one centrifugal recirculation fan to operate two different fluidized bed dryers. Am I correct?
If so, then you are at the pivotal point where you have to commit to making a decision on the equipment to specifiy for purchase. Your sketch is very educational and instructive because it reveals nearly all we need to know in order to make a reasonable comment on the type and methods of providing the continuous nitrogen medium to both fluidized beds. One single centrifugal fan used for both fluidized bed requirements in this case is a possibility - but it will require very detailed and accurate calculations as to the total head required for the fan as well as some relatively sophisticated instrumentation and surge controls. My personal preference would be to invest in two, separate and specific fans - each dedicated to the specific fluidized bed it services.
My reason for recommending two specific fans for this type of application is that sooner or later, there will be inherent process variations required - either as turndowns or turnups in the capacity of each one of the two fluidized beds. This possible process change could create havoc in the controls of either (or both) of the beds. I don't know the quality or the description of your solid material being dried in the beds, but I would presume that any excess carry-over to the cyclone separator would be a major process excursion that would create many problems. I am presumming that you must have precise and consistent process control and quality of the solid product. If my presumptions are correct, then the need for individually dedicated and controlled fans is a pre-requisite for ensuring good control and consisitent production quality.
I note that the mass flow rate of nitogen to one dryer is twice that of the other. This requires a substantial flow split and causes a totally different static head requirement for each dryer - linked to the ability to split the flow of the main stream. The fan's characteristic performance curve will be heavily taxed to avoid going into a surge condition while maintaining the required total flow for both dryers - and this is at steady state, design conditions. The moment you need to vary the flows to either dryer, the balance of the flows as well as the static heads will change - and affect the performance of the fan.
