Applications Of Pumps Nd Valves
#1 kunal_gulati
kunal_gulati
  • 9 posts
Posted 14 May 2008 - 10:21 AM
i need to know whr do we use various types of pumps and valves in industries and also domestically... plz giv as detailed answer as possible
#2 djack77494
djack77494
  • 1,282 posts
Posted 15 May 2008 - 12:27 PM
QUOTE (kunal_gulati @ May 14 2008, 07:21 AM) <{POST_SNAPBACK}>
Pumps are used to motivate liquids and overcome resistances so as to result in the liquid's movement to the desired location. Valves permit selections of alternate pathways for fluids during transfer operations and may also be used to adjust the flowrate. You cannot pose an incredible vague and general question and expect a more detailed answer, so if this response is not what you seek, then
plz giv as detailed an inquiry as possible
#3 kunal_gulati
kunal_gulati
  • 9 posts
Posted 21 May 2008 - 10:35 AM
actually i wanted to know :
5 industrial applications of centrifugal pump.
which pump do we use in petrol pumps.
whr do u find valves in an industry.. what is their significance. domestic applications of valves..
#4 djack77494
djack77494
  • 1,282 posts
Posted 22 May 2008 - 08:00 AM
Your question is very broad. What you need is for people in the pump and valve industries to respond. I have no general industry "demographic-like" data of the sort you apparently seek. Hopefully some of the forum members will fill the void; if not, go to more industry-specific websites. Good luck.
#5 JoeWong
JoeWong
  • 1,223 posts
Posted 22 May 2008 - 04:15 PM
A bit general...
I hope i am not doing homework...
Pump applications...
i) Water transfer from Water treatment unit to plant wide
ii) Chemical injection for pH adjusting in Wastewater plant
iii) Slurry transfer from reactor (i.e PVC slurry) to blowdown drum
iv) Produced water injection into well for disposal and well maintenance
v) Solid-liquid waste transfer to cake pressing
Infact, all fluid transfer...
Valve applications...
i) Isolation e.g. Block valve
ii) Throttling / control e.g. CV
iii) Overpressure / Vacuum protection e.g. PSV, PVSV
iv) Avoid back flow e.g. Check valve
v) Pump minimum flow protection e.g. ARC valve
#6 kunal_gulati
kunal_gulati
  • 9 posts
Posted 28 May 2008 - 12:30 PM
hey thanx.. no thats not any homework.. actually such questions r asked in viva.. so we need to prepare such stuff... and this forum is really helpful in getting such answers.. thanx for the reply man...
