Difference Between Tube And Pipe
#1 Anil Panchal
Anil Panchal
  • 17 posts
Posted 06 June 2008 - 11:09 PM
i am m.tech student in industrial process equipment design. What is the exact definition of pipe and tube? what is the difference among them?
#2 kumaqal.engr
kumaqal.engr
  • Validating
  • PipPipPip
  • 40 posts
Posted 07 June 2008 - 04:56 AM
Sir,
In simple words
A pipe is a vessel
A tube is structural.
We measure pipe by Internal Dia. As pipes have a consistent id regardless of wall thickness. e.g 3 inch pipe available in different Schedule no 40, 80 but it's Internal dia "ID" remain same
In case of TUBE it's Outer Dia "OD" remain same. As wall thickness vary so It's InnerDia vary but It's outer dia remain same.
#3 fallah
  • 5,022 posts
Posted 08 June 2008 - 12:43 AM
QUOTE (kumaqal.engr @ Jun 7 2008, 04:56 AM) <{POST_SNAPBACK}>
Sir,
In simple words
A pipe is a vessel
As far as i know, in the case of the pipe OD will remain same with increasing Schedule No. while ID is decreased due to wall thick. increasing.Therefore your statement in this regard isn't true.
#4 srtools1980y
srtools1980y
  • 45 posts
Posted 08 June 2008 - 04:35 AM
hi!
2 parameters decide whether it's a tube or pipe. they are wall thickness & dia.
if the wall thickness is expressed in ga(u)ge no. it's tube, whereas if it is in schedule no. or class then it's pipe.
if the dia is 6mm (1/4'') or less it's tube, whereas if it is more than 6mm it's pipe.
tube is available in coil form, not pipes due to the simple fact that pipe wall thickness does not permit coiling.
hose is non metallic tube/pipe available in coiled form.
above information holds good for sheets & plates also.
sheet thickness is expressed in gage nos. (5/6mm & less) and available in rolls, whereas plate thickness is expressed in mm/inch (5/6mm & more) & available in straight form only due to the simple fact, the thickness does not permit coiling.
hope this is useful.
goodday
srt.
