Hi everybody.
I have 2 questions:
1) I'm studying a mixture of water and ethylene in a flash separator and I'm using Aspen Plus to simulate the process. I read many things in Aspen Helps to select the thermodynamic model. For what I read I think SR-Polar is a good model to Vapor Liquid Equilibrium. But I'm still in doubt. Could be another model like NRTL with RK as vapor model or SRK ? What's the best ?
2) I'm using Aspen Dynamics the first time, so I'm having problems trying to adjust the controllers of a destillation process. I put the set-point, for instance, 0.25. When I reach Enter, the number goes to 0. I'm not able to put numbers with fraction. What am I doing wrong ?
Thanks everyone.
Thermodynamic Model And Aspen Dynamics
Started by barbieros, Jun 07 2008 10:17 PM
Posted 07 June 2008 - 10:17 PM
Posted 13 June 2008 - 09:12 PM
Does anybody know ? Even the question about Dynamics ?
Posted 14 June 2008 - 01:04 PM
the answer of your 1st question is , use SRK or PR because, the case you are simulating is Hydrocarbon based.
2nd question let to weight for some expert, come and explain the question.
Posted 22 September 2008 - 03:05 AM
QUOTE (barbieros @ Jun 7 2008, 11:17 PM) <{POST_SNAPBACK}>
Hi everybody.
I have 2 questions:
Thanks everyone.
I have 2 questions:
Thanks everyone.
I just reply the second question:
From your description, I resume that you using PID controller, when you want to active PID controller, you must connect the necessary stream, also you need to transfer the control model from manual to auto mode, so it can work well afer you finish.
By the way, to give the right P, I , D parameter is very important for you to control the process varialbes.
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
