Hi All
I will be design Strainer for pump's plant. this pump's are Screw pump for operation pumping Bitumen fluid. the Bitumen is High Viscosity & temprature . If your information's for design & selection of appropriate strainer's , Plz instruction with me by Email : sheikhmehdi@gmail.com
however, I did selected DUPLEX Basket strainer with Mesh 100 , But I want your recommendation .
thanx for your attention Group
Strainer Design
Started by sheikhmehdi, Jun 10 2008 01:51 AM
Posted 10 June 2008 - 01:51 AM
Posted 10 June 2008 - 09:08 AM
sheikhmehdi,
You may have more success if you posted this query in the Industrial Professionals forum. It has nothing to do with simulation. Also note that the purpose of this forum is to help ALL users in seeking answers to problems. We share this information, and it is generally not appropriate to request a private response.
Selection of an appropriate strainer tends to be more a matter of experience more than anything else. One would tend to use what is currently in use in this or similar applications. I do not know a priori what size mesh works well in a bitumen pump suction line. I can tell you that I used 3/16inch openings in a recent Vacuum Tower Bottoms pump suction. That is a nasty service with the possibility of coke fines being present, so we had duplex (two in parallel) strainers. I know bitumen is a nasty service, but I don't know if it's that bad. 100 Mesh seems quite fine to me, but again it's a matter of experience.
Good luck,
Doug
Good luck,
Doug
Posted 10 June 2008 - 10:56 PM
Hi DJACK
Thanx for your comment. the first , I am a new account in Forum, so thanx for knowing me.
The second : indeed , we have a COCK POT in plant's for suction pump's . unfortunatly, is not appropriate Volume & mesh size & ... of resone coke accumulation and less time PM ( Preventive maintenance) . now , we want design a Coke pot OR Strainer Or ..... for undestructive Screw Pump's plant . if you of information about associate company's , PLz tell a Network Address .
Thanx for again attention
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
