I have come across a problem in my project which i am sure is not uncommon. We have a exchanger circuit for Alkylate product ( please see the attached sketch), The exchanger in question is a makeup heater where tube side is operating at 24.8 Kg/cm2,g (design pressure 60 Kg/cm2,g) & shell side is operating at 7.6 Kg/cm2,g.
In order of following 10/13 rule , our detailed engineering contractor has fixed the shell side design pressure as 10/13*60 = 46.15 ~ 47 Kg/cm2,g.
The discharge & suction side (with respect to makeup heater ) equipments & their design pressure are also displayed in the sketch.
My line of thinking is that even though the shell side of makeup heater is protected in case of tube rutpure & doesn't require any PSV ,the suction & discharge side equipment & piping are not protected as they are designed for considerably lower pressure . In this case do we need to provide a PSV on the makeup heater shell side (or suction/discharge piping) to protect upstream/downstream equipments in case of tube rupture of makeup heater ?
I have asked this question to my seniors & other colleagues but so far they have not given any satisfactory answer to convince me hence i thought that many of you might have come across some scenaios & in better position for answering above question ?
Vinay
