I have some two phase flow problems. As the vapor and liquid flow in the pipe, I should how to define the flow patterns and calculate the pressure drop in the pipe. I already had get some information about small size pipe < 4inch from "LUDWIG Chapter 2 Fluid Flow". But for the big pipe, I still have no concept. Could anyone provide any information about defining flow patterns and calculation method of pressure drop?
Besides, which flow pattern would possibly damage the piping or fitting? Having Any method avoid it ?
Two Phase Flow Problems
Started by cheerpolo, Jun 12 2008 12:15 PM
Posted 12 June 2008 - 12:15 PM
Posted 12 June 2008 - 01:56 PM
Hi Cheerpolo,
I have studied multiphase processing in my PGD, Hope I can Help you, send me your problem at following email and let me check it.
Sure, I will reply and I suggest some books also.
Email:sadartoorr@gmail.com
Posted 15 June 2008 - 05:14 PM
I recommend CFD (e.g. software Fluent and use of Mixture Model, which is a simplest eulerian approach to modelling of multiphase flow).
Posted 03 July 2008 - 02:03 AM
For two phase flow one approch is to calculate pressure drop assuming either the gas or liquid is flowing alone and then the two phase flow can be calculated from an empirical, usually non-linear correlation based on the two single-phase results.
see paper by Lockhart & Martinelli (1949)
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
