In finding the thickness of pipe subjected to internal pressure & external pressure what are the codes being followed in general practice. How design for external pressure is diferent from that for internal pressure.
Thanks in advance
Piping System Design
Started by rsk, Jun 20 2008 12:32 AM
Posted 20 June 2008 - 12:32 AM
Posted 20 June 2008 - 09:23 AM
The ASME 31.x series of codes is commonly used for piping. What "x" is depends on the type of facility you are designing for. Process piping uses 31.3; utility systems and pipelines use different variations. I believe that all piping meeting these codes would be good for full vacuum, but remain ready to be educated if this is not true.
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
