I have to validate oil-water separator. At first, i check for maximum particle drop diameter and residence times but this methods not guarrantid the outlets compositions. Now, i looking for something else. I need to know if there is some standarized or normaized laboratory method to check the separation at diferent residence times.
Oil-water Separation
Started by Guest_JMP_*, May 03 2003 02:13 PM
Guest_JMP_*
Posted 03 May 2003 - 02:13 PM
Posted 05 May 2003 - 11:03 AM
contact the oil-water seperator manufacturer - they should be able to help.....
Guest_Waqas Habib_*
Posted 06 June 2003 - 07:47 AM
See the ASTM method for determining the residence time vs separation efficiency. Or you determine your own method for calculating this time at your desired temperatures and compositions. I do not remember the ASTM number
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
