I am in a big dilemma whether it is possible to use Nitrogen for actuation of Deluge Valve system for fire protection of LPG Horton Sphere,
My vendor has given me a system in which he is pressurizing the actuation line by Air going to Quartzoid bulbs, now as the continuous availability of air at our project terminal is a major concern but Nitrogen is continuously available from outside supplier so I thought of using nitrogen instead of air for pressurization purpose.
I am having a concern of normal leakage of nitrogen through due course of time which can produce a cooling effect in pipeline material.
Also does fire protection code permits the use of Nitrogen for such kind of service ?
Please put your valuable comments on this asap.
RN
Lpg Horton Sphere Fire Protection System
Started by Dev 009, Jul 08 2008 02:31 AM
No replies to this topic
Posted 08 July 2008 - 02:31 AM
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
