As show in schematic
1. Heat dissipated by nuclear spent fuel in system tank at rate of q MW is being removed by circulating water through HX in a primary closed loop system which in turn transfers heat to secondary cooling system.
2. Pump Required Flow through HX for a specified differential temperature DT can be found as
(q/cp* DT ) & taking margin for purification flow as 5%. Gross pump flow is 1.05(q/cp* DT ).
3. Pump developed head will be to cater for frictional losses through suction & discharge lines & HX ie (hs+hd+h HX).
4. System inventory including piping & equipment is 500m3 & normal temperature is 40 deg & expected variation is +/- 2 deg.
5. How shall i approach for sizing of expansion tank ie Volume & elevation abovepump centre line.
6. shall i consider expansion tank to be riding at suction or at discharge & where on suction or discharge lines. what is the basis.
7. additional Data are Pv vapour press of water at 40deg & Hs is the NPSH required for the pump.
8. How elevation of expansion tank will affect hydraulics ie system resistances curves.
