Hello ,
I look for a chart or any thing else to read or convert an amount of water in PPMv to the equivalent dew point temperature.
thanks
ex: I have 1 pmmv water in gas , what is the dew point .
thanks.
Convert Ppm To Temperature
Started by engprocess, Jul 31 2008 11:22 AM
Posted 31 July 2008 - 11:22 AM
Posted 31 July 2008 - 03:19 PM
EngProcess,
First of all, you need to know the total pressure of the gas. Knowing the mole fraction of water in the system(=vol fraction), you can obtain the partial pressure of water. According to Raoult's law,
Partial pressure= vapour pressure of water*activity coefficient
For simplicity, you can assume activity coefficient of 1. Thus you obtain your vapour pressure. From here it is as simple as checking a saturated steam table for the temperature that corresponds to this pressure(vapour). That's your dew point!
Posted 01 August 2008 - 06:38 AM
Please also refer following recent posting on cheresources.com related to Dew point
http://www.cheresour...?showtopic=5961
regards,
vinay
regards,
vinay
Posted 03 March 2009 - 11:42 PM
You can download a freeware calculator from www.phymetrix.com that will perform all of these conversions.
Hope this helps!
Hope this helps!
Posted 05 March 2009 - 04:07 AM
Hi Hygrometry,
Thanks for the excellent tip. That is a pretty good calculator.
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
