Kindly intimate if any IEC or NFPA standard exists which mentions that provision of Automatic fire suppression system is a mandatory requirement for electrical facilities like switch gear room or motor control centers.
These automatic fire suppression systems use Inergen or CO2 to extinguish the fires.
Thanks,
Automatic Fire Suppression System For Switch Gear Room
Started by omarshuja, Aug 07 2008 03:42 AM
Posted 07 August 2008 - 03:42 AM
Posted 20 August 2008 - 09:23 AM
Omar,
Yes Even NFPA has a complete code list NFPA 2001 for clean agent suppression systems like for instance in a switch gear room or any electrical room there is a " C " class fire which can be extinguished by Clean agents like FM 200,Pro inert,CO2 etc depending on the human occupancy of the place.
More information can be get from me at 00923334257954
Posted 24 August 2008 - 09:55 PM
Thanks for your reply.
NFPA does has a standard regarding fire suppression system but my question is that does any NFPA standard mentions that an automatic fire suppression system (Inergen, CO2, etc) is mandatory for an electrical installation like Switch gear room, etc.
Thanks,
Omar
Thanks,
Omar
Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , Yesterday, 03:06 PM |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
