Column Dia - 150 NB
Column Lenght - 12 Mts
Pressure at different location
At the source ( At the vacuum Header) 711 Torr
After condenser 700 Torr
At the top of the column 620 Torr
At the bottom of the column - 580 torr
DP across the column - 40 torr
Operating temp - 130 Deg C
Utility in condenser - Cooling Water
Vapor Flow - 75 Kg/hr
R.R - 5
Product flow rate - 15 Kg/hr
The problem i am facing in vacuum distillation is the pressure drop across the condenser which is around the 80 Torr. I had done the calculation for the pressure drop accoridnng to the velocity at the operating temp and pressure which is coming out low. The velocity of the vapor is20 m/sec. As per my knowledge at 60 Torr, the 50 m/sec velocity is good
What are the possible reson for it and are the critical paramtre which i have to take care for calculation
