Solar energy technologies use solar radiation for practical ends. Technologies that use secondary solar resources such as biomass, wind, waves and ocean thermal gradients can be included in a broader description of solar energy but only primary resource applications are discussed here. Because the performance of solar technologies varies widely between regions, they should be deployed in a way that carefully considers these variations.
Solar technologies are broadly characterized as either passive or active depending on the way they capture, convert and distribute sunlight. Active solar techniques use photovoltaic panels, pumps, fans and to convert sunlight into useful outputs. Passive solar techniques include selecting materials with favorable thermal properties, designing spaces that naturally circulate air, and referencing the position of a building to the Sun. Several common materials are titanium dioxide,stannic oxide and so on.Active solar technologies increase the supply of energy and are considered supply side technologies, while passive solar technologies reduce the need for alternate resources and are generally considered demand side technologies.
Applications Of Solar Energy Technology
Started by raymond723, Aug 17 2008 09:42 PM
No replies to this topic
Posted 17 August 2008 - 09:42 PM
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Subcooled Reflux And Energy UsageStarted by Guest_jango_* , 20 Dec 2024 |
Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
Useful Set Of Tools Related To EnergyStarted by Guest_breizh_* , 19 Nov 2024 |
