Hi All,
I'm working on an offshore platform and on some of our wells, it was noticed that certain annuli were showing zero pressure at the surface pressure gauge. When attempting to perform flow tests on these annuli it was confirmed that some of them were actually under vacuum. This situatuion introduced the following potential risks:
- Collapse/burst of casing
- Metal corrosion due to oxygen introduced into the annulus
- Inability to accurately monitor annulus pressure
In order to ensure proper monitoring of the annuli pressures as well as minimize all vacuum related risks, annuli need to be filled with inhibited (injection) seawater and pressurized to approximately 5 barg.
I was wondering if anyone else has faced this problem in the past and could share experience and knowledge.
Thanks.
Fill Well Annulus
Started by Megalith, Sep 03 2008 11:47 PM
No replies to this topic
Posted 03 September 2008 - 11:47 PM
Change In Ndct Diameter/height, If Splash Fill Is Changed To Film FillStarted by Guest_ssphogat_* , 11 Mar 2015 |
How To Calculate The Initial Solvent Fill In A ColumnStarted by Guest_alchemist_* , 15 Nov 2014 |
![]() How To Calculate Time To Fill Gas In Closed Vessel/storageStarted by Guest_tnjtnj_* , 28 Jul 2009 |
![]() Ammonia Storage Tank, Shut Off Valve Inside AnnulusStarted by Guest_Chem01_* , 28 Mar 2009 |
Lpg Storage Tanks Maximum Liquid Level And Fill RateStarted by Guest_terry e quinn_* , 26 Aug 2008 |
