Dear colleague:
1-Due to limited capacity of flare system we have to sequentially depressurize gas trains and also some other units through flare system.
Max capacity of each gas train/other units and flare tip capacity is available.
Could U advise me regarding procedure for this calculation?
2- if there is a vessel with specified V, p1&T1 which contain compressible gas fluid, if it starts depressurizing to p2. Is it possible to calculate outlet flow rate during depressurizing? How?
Depressurizing
Started by mohammadhosseinzadeh, Sep 09 2008 04:26 AM
Posted 09 September 2008 - 04:26 AM
Posted 10 September 2008 - 08:22 AM
There is a nice article that contains all info you need and more, "How to predict temperatures during gas depressuring", by G. Montgomery, Hydrocarbon Processing, April 1995, p. 85-88.
It is all pretty straightforward, using gas law, heat transfer equations, mass balance considerations, and valve flow equations. I am sure you could even figure it out by yourself.
Posted 11 September 2008 - 03:37 AM
It is quit possible with fundamental equations:
But you have to give on more variable that is crossetional area (A)of piping to depressurisation.
Loss in pressure energy during depressurusation = Kinetic energy of gas releiving with certain velocity.
Allowable Velocity can be calculated by limiting mach no 0.3 to 0.4.
Q (m3/h) X (p1-p2) =1/2 m v2
substitute value Q = v x A
=> m =2*(p1-p2)*A/v (kg/hr)
Calculatiom of v.
V sonic =(KT/Mw)^.5
V allovable = 0.4*v sonic
Formulae to be checked from any text for unit consistancy
Shahnawaz
Calculatiom of v.
V sonic =(KT/Mw)^.5
Shahnawaz
Posted 11 September 2008 - 12:58 PM
Mohammad:
I suggest that you read this article:
http://en.citizendium.org/wiki/Accidental_release_source_terms
It provides the the correct equations for use in the choked flow and the non-choked flow of gases for use in accidental gas releases or in routine depressurization of gas-filled vessels or pipes.
Milt Beychok
Milt Beychok
Posted 14 September 2008 - 01:29 AM
thanks all for useful information
joerd:
could you please send me this article:
Email:m.hosseinzadeh.78@gmail.com
joerd:
Posted 15 September 2008 - 08:41 AM
Sorry, it is copyrighted. You can request it at http://www.hydrocarb.../hp-photos.html
or give it a try at your local university library. Good luck,
Posted 07 December 2008 - 04:35 AM
QUOTE (MAKROO @ Sep 11 2008, 03:37 AM) <{POST_SNAPBACK}>
Calculatiom of v.
V sonic =(KT/Mw)^.5
Dear mr shahnawaz ,plz explain teh meaing of KT you used in above equation for Vsonic..,r they soem contants ..if yes then plz give there vaules.
Shahnawaz
Calculatiom of v.
V sonic =(KT/Mw)^.5
Shahnawaz
Sour Pipeline DepressurizingStarted by Guest_Ghasem.Bashiri_* , 10 Sep 2021 |
Hydrate Formation During DepressurizingStarted by Guest_Ghasem.Bashiri_* , 11 Aug 2021 |
Depressurizing Calculation In Gas Filled SystemStarted by Guest_Ghasem.Bashiri_* , 12 Mar 2021 |
Sizing Blowdown & Depressurizing LineStarted by Guest_ZAI_847_* , 04 Jul 2019 |
![]() Coefficient Of Discharge For Depressurizing OrificesStarted by Guest_Dieguito2_* , 03 Mar 2019 |
