I would like to know the definition of sensitive temperature in distillation.
Thanks.
Sensitive Temperature
Started by abhagat60, May 09 2004 03:05 PM
Posted 09 May 2004 - 03:05 PM
Guest_Guest_*
Posted 14 May 2004 - 06:52 AM
...u have sensitive and latent heat
...latent heat is heat from vaporatisation,condensation,melting etc ( T=const)...rest is sensitive heat
...so,if u want to warm up water from 20-120 °C u need:
-sensitive heat-from 20-100
-latent heat-100 (boiling)
-sensitive heat-100-120
Posted 19 May 2004 - 07:30 AM
I think you may refer to the temperature on a tray or at a specific location in the column that would change a lot if the purity at one end or both ends changes, and that may be used for control
Posted 19 May 2004 - 12:41 PM
QUOTE (Guest @ May 14 2004, 03:52 AM)
Guest:
The correct terminology is "sensible" heat rather than "sensitive" heat. In any event, I think that Abhagat60 (who started this thread) was asking about something other than sensible heat.
PLEASE, in your future postings to this forum, spell out "you" rather than using simply "u".
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
