i think since the ion of CL- exists in the aqueous solution so you can never make it possible to below 5ppm,even you put more alkali in it or give more heat in it(such as using distillating tower).
at last the NH4+ will turn to the solid(NH4CL) with the water decreasing.
all the salt solution are the same like the NH4CL .
is the idea true? can somebody so kind that give me a explanation or advise some website.
anything i didn't say clearly ,don't hesitate to write back to me .
