Amine Solution In Boiler Feed Water
Posted 28 September 2008 - 01:07 PM
I am designing a deaerator and BFW pumps system.Referring to the P&IDs of different plants i found that amine solution has been added at the suction of BFW pumps.
I think the need for adding amine solution is to increase the pH of Boiler Feed water.
But i feel cant we inject the amine solution in the deaerator itself instead of injecting it in suction line of BFW pumps.
Is there any particular reason behind this.
Posted 28 September 2008 - 11:54 PM
Posted 29 September 2008 - 06:12 AM
we add amin to deaerator tank and no problem is here.
for better mixing we use a spraying nozzle for amin.
amin act as oxygen scavenger and PH controler to preventing corrosion in boilers.
regard
Posted 30 September 2008 - 06:02 AM
Hi friend:
As Amine is volatile ,it should be injected outlet of dearator.
Posted 03 November 2009 - 03:07 PM
I think in addition of reasons, the main function of amin is neutralising of co2 which my be produced in decomposition of bicarbonate of boiler water in high temperature.<!--quoteo(post=22316:date=Sep 28 2008, 01:07 PM:name=process85)--><div class='quotetop'>QUOTE (process85 @ Sep 28 2008, 01:07 PM) <a href="index.php?act=findpost&pid=22316"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Hi
Is there any particular reason behind this.<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi friend:
best regards
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
