Hi every one
I work in gas Industry. I need to find that how long it takes to corrode Carbon steel and Stainless steel. We are using Amine system (DGA). As a matter of fact i like to calculate corrosion rate for carbon steel and stainless steel using Co2 properties. the issue is that i don't have the equation with me. Is there any one who can help me or give me a clues about the equation?
I really appreciate your help.
Thank you very much
Corrosion
Started by process101, Oct 08 2008 12:45 PM
Posted 08 October 2008 - 12:45 PM
Posted 07 November 2008 - 09:10 AM
Hi
If you need to calculate corrosion due to CO2 you can use the model of DeWaard-Milliams and following modifications. There are also free software like the NORSOK M 506 that allow you to calculate corrosion in Oil&Gas due to CO2 or also the FreeCorp.
corrosion prevention oil&gas
hope this help u
Vittorio
Posted 07 November 2008 - 12:11 PM
I have used the NORSOK M-506 program. It is NOT USER FRIENDLY and requires a lot of work. It is recognized by major operators in the field.
The Freecorp software from Ohio University seems to be very user friendly and easier to install and use. I have not used it yet, but I would expect it to have a place in predicting CO2 corrosion rates.
Posted 05 March 2009 - 09:13 AM
QUOTE (Art Montemayor @ Nov 7 2008, 01:11 PM) <{POST_SNAPBACK}>
The Norsok model is not so complicated, i mean you need some backgorund on corrosion but if you study some papers on CO2 corrosion it's a very good software
if u need help, just ask and iìll suggest u how to use it
V.
Corrosion In RefineriesStarted by Guest_CHEMSTRONG_* , 19 Jun 2022 |
Refinery Corrosion InhibitorsStarted by Guest_CHEMSTRONG_* , 03 Apr 2022 |
Corrosion Under Deposition At Trim Cooler Of Rfcc Main Fractionator OvStarted by Guest_Eric Nguyen_* , 19 Jul 2021 |
Does Ptfe Based Grease React With Anti-Corrosion Agents And Dissolve IStarted by Guest_Sam1999_* , 29 Apr 2021 |
Oil And Gas Processing, Water Treatment And Corrosion Free BooksStarted by Guest_Yasserkassem_* , 05 Feb 2021 |
