Gate And Check Valve Issues
Posted 24 October 2008 - 12:16 AM
There has been many failures on the gate valves and check valves
Gate valve; Gate comes loose from stem
Check Valve; Flappers become dislodged from valve body
Service: Produced water
Operating Temp : 38C
Operating Pressure : 4.5 Kg/Cm2
Design Temperature : 71C
Design Pressure : 8 Kg/Cm2
Valves rating 150 Material Carbon Steel
Posted 24 October 2008 - 06:08 AM
Waterhammer - if you have this it could cause lots of problems with valves in the system. Do not look for valves that can withstand water hammer, but rather find the root cause and fix it.
Valves: You may have a particularly bad valve, or a bad run of valves. Are these from different manufacturers or are they various?
Posted 24 October 2008 - 09:20 AM
Posted 27 October 2008 - 02:10 AM
A few issues could be :
i) Corrosive component i.e CO2, H2S, etc
ii) Erosive component i.e. solid, sand, sludge, etc
iii) Gas and HC condensate passing
iv) High velocity passing
Posted 27 October 2008 - 03:41 AM
Few suggestions;
1) Have any corroded components analyzed? if not they should be analyzed to know the main corrosion products at the worst affected locations.
2) If any of such above identified causes by our JoeWong,Doug are ruled out; then Most probably the material defect/suitabilty for service or Bad batch(as identified by Joesteam) remain probable one's I believe.
Best regards
Qalander
Posted 28 October 2008 - 12:56 PM
In most cases we have found the cause to be poor design/ quality of the valve by the manufacturer. This is the case when your purchase department goes for the L1 (lowest) bid. We solved the problem by stringent check of the valve manufacturers’ credentials and listing out ‘preferred manufacturers/ suppliers’. Going for reputed manufacturers, often saves costly down time and ensures that they stand by their guarantee.
Posted 28 October 2008 - 04:03 PM
We, as designers were pushed by the clients to use minimum 300# rating, they had some bad experiences with lower ratings.
Posted 29 October 2008 - 02:18 AM
Some questions...
The design condition demand for 150#. Any specific reason you need to go for 300# ?
Posted 29 October 2008 - 08:51 AM
There is no process requirement not so ever. It is only from a reliability stand point. Again, it was an operator request, and it's not a rule.
Cost wise is probably cheaper to have all the fittings 300# than keep fixing some failing 150# ones, I never did the math. There were clients that said they've replaced all 150# fittings to get rid of the problems.
#10
Posted 29 October 2008 - 11:29 AM
Ah...OK...That's what i guess...
Thanks for your explanation.
#11
Posted 30 October 2008 - 11:55 AM
#12
Posted 10 November 2008 - 12:50 AM
Discharge flow is 3000 US GPM; valve size is 12" and dicharge line goes to 24" header. These valves are subject to high velocity and causing failure?
#13
Posted 10 November 2008 - 07:42 AM
The stated problems are defined as:
The question was:
Has any one encountered the problem given below? Any feed back will be highly appreciated.
In the course of 48 years, I have had many failures of both gate valves and check valves - each of 150# or 300# service ratings. It is a simple engineering error and overly simplistic explanation to assert or insinuate that 300# valves will function with more robustness or "toughness" than 150# ones. This is a wrong analysis that has no logic.
It is the QUALITY of what you buy (or your purchasing department buys) that has something to do with the quality of what you install and operate. The internal design, casting, forging, machining, and assembly of the valves has ALL to do with the resultant quality of the product - whether it is 150# or 300#.
I would not purchase a gate or check valve designed and fabricated in China at this time unless I had certification that it was totally fabricated AND inspected to the standards and specifications that I am familiar to - not to local Chinese standards that I am unfamiliar with and have no control over. I apply the same purchasing decision to everything I buy - regardless of where it is fabricated.
Quality is the underlying reason for the success of operating equipment and if you don't insist on it and demand it, the results are usually bad.
#14
Posted 10 November 2008 - 12:08 PM
At 3000 US GPM, your velocity (more than 8.5 fps) is rather on the high side. However, if the length of the 12" pipe up to the 24" header is not much, it is quite acceptable. Is the valve close to the 24" header? Is there any gas entrapped in the produced water? Is there a possibility of a two phase flow?
Normally, the gate valve is used in fully closed or fully open position only. It is not recommended for use in controlling the flow. I have, however, come across several instances of gate valves being used to throttle the flow. This can also cause frequent failure of the valve especially when subjected to high velocity flows – more so if the quality is questionable. As I had suggested earlier, could you dismantle the valve for investigating the cause?
If you think I am not inquisitive could you please let me know the manufacturer of the valve, type of valve (rising spindle or rising gate) etc.? I would like to see if I can get a cross section of the valve from the manufacturer’s website. Some details of the industry / country you are working in etc. would help too.
Thanks.
#15
Posted 11 November 2008 - 03:07 PM
![]() Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
