Lhv/hhv Conversion On Mass And Volume Basis
  • guestGuests
  • 0 posts
Posted 18 November 2008 - 06:21 AM
Hello newsgroup,
I am struggling with a conversion of HHV to LHV based on the amount of water in a gas mixture. This is what its about:
Gas composition mole frac:
H2O: 0.0395
N2: 0.3682
CO: 0.3311
CO2: 0.043
H2: 0.2183
I can now calculate the higher heating on a dry mole basis (i.e. excluding water) based on the enthalpy of combustion for CO (283 kJ/mol) and H2 (608 kJ/mol), giving me 235 kJ/mol, for a molar volume of 24.789l/mol this results in a higher heating value of 9510 kJ/Nm3.
However, I am baffled on how to converting this into a LHV now. All formula I have found are based on estimations for fuels, but the composition used there varies way too much that I would like to use them...
Thanks a lot and best regards,
MatL
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 18 November 2008 - 09:28 AM
LHV and HHV are the same when the combustion of the fuel gives no water as a combustion product. For CO the HHV and LHV are the same. Please see the following link to download a spreadsheet I have posted regarding combustion calculations.
http://www.cheresour...;hl=spreadsheet
  • guestGuests
  • 0 posts
Posted 18 November 2008 - 11:17 AM
Hi Ankur,
and thanks a lot for your message.
QUOTE (ankur2061 @ Nov 18 2008, 02:28 PM) <{POST_SNAPBACK}>
This i see, but that doesn't hold for the hydrogen in the gas. And there's also the fact that some share of the gas itself is water vapor, so when calculating the heating value of this, then the heat of evaporisation of this water must be included as well, or am i on the wrong path here?
MatL
#4 djack77494
djack77494
  • 1,282 posts
Posted 19 November 2008 - 06:11 PM
QUOTE (MatL @ Nov 18 2008, 07:17 AM) <{POST_SNAPBACK}>
MatL,
I'm going with Option 2 here (you're on the wrong path). You're dealing with a gaseous fuel that has a bit of humidity (the water vapor). Ignore the water vapor - it does not contribute to the fuel's heating values.
HHV and LHV are defined values that begin with the compounds in the fuel that will be combusted. That is basically carbon, hydrogen, and sulfur bearing compounds that are oxidized (combusted) in the process. Nitrogen, carbon dioxide, water vapor, and sulfur oxides can be considered inert. You may use ankur's generously provided spreadsheet to calculate your heating values which apply the standard definitions -
C + O2 ----> CO2
CO + 1/2*O2 ----> CO2
H2 + 1/2*O2 ----> H2O
S + O2 ----> SO2
For HHV, the water product is assumed to be in vapor form and for LHV it is assumed to be liquid.
  • guestGuests
  • 0 posts
Posted 27 November 2008 - 09:50 AM
Hi djack,
QUOTE (djack77494 @ Nov 19 2008, 11:11 PM) <{POST_SNAPBACK}>
MatL,
thanks a lot - now I got it! It took a while, but now I see - it's only the water that is formed by the reaction that impacts the LHV, not the water present... that makes sense wink.gif
Thanks and best regards to you both,
MatL
