Dear friends,
We have installed a thermic fluid heater with the following details.
Pump Flowrate : 30 M3/Hr
Coil pipe dia : 40 mm
Coil outer dia : 700 mm
No of turns: 36
Density of oil: 1200 kg/m3
Pipe material of construction : Mild Steel Sch 40
We want to calculate the pressure drop across the coil, we have used darcy-weishbach equation but not satisfied with the results.
Can anyone suggest anyother equation to calculate the pressure drop across the coil.
Thanks & Regards
Ramnathsharma
Pressure Drop Across Coil In Thermic Fluid Heater
Started by ramnathsharma, Nov 19 2008 04:36 AM
Posted 19 November 2008 - 04:36 AM
Posted 19 November 2008 - 05:44 PM
Please see if you can find some information in Kern Heat Transfer book...
Posted 20 November 2008 - 03:16 AM
Dear Ramnath,
Check out this weblink. It gives equations and also a calculator for tube pressure drop for fired heaters. You can do a preliminary check and compare it with your earlier results. You can also ask your fired heater vendor to provide you the pressure drop information.
http://www.heaterdesign.com/wintherm/
Hope this helps.
Hope this helps.
Posted 25 November 2008 - 12:16 AM
You have to use D-W equation for pressure drop calculation except that friction factor should be calculated as mentioned in Perry's 6-18 and 6-19. The flowrate seems to be quite high for a 40NB pipe. Are you sure about the above data?
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
