did any one try to compare the results for vessel depressuring between hysys (unisim) and pro ii ?
In pro ii what is the recommended steps to size the depressuring valve or orifice ? any particlure areas to consider ?
cheer,
sm
Depressuring Hysys Vs Pro Ii
Started by smalawi, Nov 19 2008 09:10 AM
Posted 19 November 2008 - 09:10 AM
Posted 19 November 2008 - 05:57 PM
My comments may discouraging nor disappointing some parties... i decided to keep...
Just simple advice...
Establish good basis for PV term and isentropic efficiency...
be careful flowrate and temperature predicted by HYSYS...
be careful temperature predicted by Pro-II...
Reader may choose to ignore my "observation"...
Posted 21 November 2008 - 10:19 AM
QUOTE (JoeWong @ Nov 20 2008, 02:57 AM) <{POST_SNAPBACK}>
I have checked my calcualtions with both Hysys (Unisim) and Pro II
Seems the results are very deferent and I cant tell which one is more accurate. I can compare the results with maual calcuations but still these are approximations !
Why would you say the flow and temperature in Hysys is questionable ?
Also why temperature in Pro II is questionable ? (Actually I see that it gives higher temperature than expected)
The PV term eff is about 100%, it could be lower but unless I have good reasons not to design at that temperature such as cost and delivery I will use it.
Aprecaite more comments and experiance based advise, for such a standared calcuation there seem to be more to learn !
cheers,
SM
Posted 22 November 2008 - 06:49 PM
QUOTE (smalawi @ Nov 21 2008, 11:19 AM) <{POST_SNAPBACK}>
What i really suggest to you is that browse through the HYSYS and Pro-II manual and looks for the equations used.
Secondly compare the detail results i.e heat transfer coefficient used, any mass inclusion, etc in order to identify the differences.
Did you use Groth equation for manual calculation or other method. Groth method only applicable to vapor only system.
QUOTE
Results from Rigorous model and experiences...that's all i can say...
QUOTE
Read more in this... Hope it helps.
Isentropic Efficiency And Its Implications
