As i compared new Rev. of API 521 (2007) with previous one,i saw huge difference in one case for comparing the smokeless capacity of air and steam as below:
-In section of 4.4.3.1.3 of previous Ver. (1997) we see:.....required is approximately 20 percent greater than.....
-In section of 6.4.3.2.4 of new Ver. (2007) we see:..... required is approximately 200 percent greater than.....
I am wondering about becoming a value 10 times larger in new Rev.
I would be very appreciated to hear from you about the reason(s).
Huge Difference Between Two Versions Of Api 521
Started by fallah, Dec 03 2008 05:13 AM
No replies to this topic
Posted 03 December 2008 - 05:13 AM
![]() What Is The Difference Between Api 521 Sixth Edition & Seventh EdiStarted by Guest_Murtaza Lashkerwala_* , 13 May 2024 |
![]() Difference Of Face Velocity In Aircooler Unit With Multiple Services.Started by Guest_AnbIran_* , 20 Mar 2023 |
Difference Between Estimated Stream And Actual StreamStarted by Guest_skyicetel1_* , 20 May 2022 |
![]() Temperature Difference Heat ExchangerStarted by Guest_Petridou_* , 04 Mar 2021 |
Difference Between Pump And CompressorStarted by Guest_Charan_123_* , 10 Dec 2018 |
