Thumb Rules For Process Engineers
Posted 06 December 2008 - 02:49 AM
My new offer for all of you regarding to Knowledge Sharing is a spreadsheet called "Thumb Rules For Process Engineers" and covers the following subjects:
PIPING PRESSURE DROP : For Raynold's no 2100 to 106
EQUIVALENT LENGHTS for Pressure drop in the system
MAXIMUM ALLOWABLE FLOW OF STEAM THROUGH PIPE 41, 12 & 2" only
ALLOWABLE VELOCITIES FOR PROCESS FLUIDS
SONIC VELOCITY CALCULATION
PERMANENT HEAD LOSS THROUGH ORIFICE
VENTURI Pressure Drop
FLOW RECTANGULAR WEIR
CONTROL VALVE SIZING
RELIEF VALVE SIZING FOR LIQUID EXPANSION
STORAGE VESSEL VOLUMES
NPSH
Pressure Drop in Pipeline
TUBESIDE PRESSURE DROP IN SHELL & TUBE HEAT EXCHANGER
MOTORS kVA
MOTORS AMPS ETIMATE
CENTRIFUGAL COMPRESSOR HP
CENTRIFUGAL COMPRESSOR HEAD
TEMPERATURE RISE IN COMPRESSION
PUMP EFFICIENCY
PUMP HORSE POWER
RELATION OF HP, IMPELLER DIA & SPEED
RELATION BETWEEN PUMP HEAD, IMPELLER DIA & SPEED
CHANGE IN PUMP CAPACITY WITH IMPELLER DIAMETER
TUBESIDE PRESSURE DROP IN AIR COOLED HEAT EXCHANGER
MOTOR HP OUTPUT
MOTOR TORQUE
GAS EXPANDERS : AVAILABLE ENERGY
POWER FACTOR
SELECTION OF TYPE OF VACUUM EQUIPMENT
FAN / BLOWER OR COMPRESSOR
SPRAY WATER FOR PRDS
MAXIMUM AVAILABLE ENERGY (EXERGY)
FUEL TO AIR RATIO
COOLING TOWERS : WINDAGE LOSSES
COOLING WATER CONCENTRATION RATIO
APPROXIMATE EFFICIENCIES OF COMPRESSORS
Physical Properties
Anyone who is interested of having a copy of it can send hid/her request to my e-mail address (jprocessman@yahoo.com)
Best of Luck,
Mojtaba
Posted 07 December 2008 - 05:59 PM
Posted 08 December 2008 - 01:43 AM
Posted 13 December 2008 - 09:06 AM
I am Chatree. I also want such spreadsheets, and please send me on my email address csangsawai@yahoo.com
Thank you for your kind cooperation.
Chatree
Guest_srinivas_*
Posted 17 December 2008 - 12:53 AM
u can send to srinivasmr@rediffmail.com
bye
srinivas
Posted 17 December 2008 - 01:36 AM
Posted 18 December 2008 - 12:51 AM
I am interested in your spreadsheet. Kindly send it to abiodun.a@atlasengineering-ng.com
Posted 18 December 2008 - 06:52 AM
pl.send it to sam.kas26@yahoo.com
reagrds
Posted 20 January 2009 - 01:17 PM
My ID is
rahuldave20@yahoo.co.in
#10
Posted 20 January 2009 - 10:29 PM
Thanks for sharing such a useful information to all process engineers.
Komal
#11
Posted 22 January 2009 - 01:45 AM
As a part of your sharing base, please arrange to forward me these data as well
My ID is, bhorps012@gmail.com
#12
Posted 26 January 2009 - 07:47 AM
Dear Sir,
Please forward these information to shansuresh79@gmail.com. Thanks for your time,
with regards,
Suresh.
#13
Posted 29 January 2009 - 04:08 AM
Please send to lukmanls@yahoo.com
#14
Posted 31 January 2009 - 02:15 AM
Pl forward the spreadsheet calculation to my address
momsalih01@yahoo.co.in
#15
Posted 31 January 2009 - 02:35 AM
i am interedted in your spread sheet, i will be very pleased if you forward the sheet to my email:
shahranimz@kemya.sabic.com
#16
Posted 01 February 2009 - 12:04 PM
i am interested in your spread sheet, i will be very pleased if you forward the sheet to my email:
yes,i am interested in your spread sheet, i will be very pleased if you forward the sheet to my email: kindly send it in my email id dil_y4k@rediff.com
regards,
DILS
#17
Posted 03 February 2009 - 02:53 AM
Will you send Thumb rule sheet in my email id umcool28@yahoo.co.in
#18
Posted 03 February 2009 - 10:10 AM
simon.j.crossley@gmail.com
cheers
#19
Posted 15 March 2009 - 09:53 AM
mwgibson@juno.com
Thank you.
#20
Posted 15 March 2009 - 04:53 PM
Please send me the file to my mail: smpatra@hotmail.com
Kind regards,
Satyajit
#21
Posted 16 March 2009 - 09:28 AM
BEWARE!! PLEASE DO NOT USE ANY SPREAD-SHEET BEFORE VALIDATING THE RESULTS.
I've seen hundreds of spread-sheets in my career so far, mostly developed by industry professionals, I too have my own spread-sheets which I use time to time. The biggest probem with these spread-sheets are, they seem to work perfectlly fine as long as user knows how it works and how to interpret its results. But for a new user, it is a very risky business.
Please use this spread-sheets with extreme caution, know what are the limitations of the calculations, know how to interpret the results. Make sure that there are no macros.
I would recommend that one should always try to solve a sample calculation by hand and verify the results of the spread-sheet to make sure it works.
Wrong results coming out from these spread-sheets might lead to a faulty design which can to a lead to a catastrophe injuring or even killing people.
ARAZA.
#22
Posted 17 March 2009 - 06:02 AM
#23
Posted 18 March 2009 - 06:08 AM
I Would Like To Have A Copy.
mehrdad85900@yahoo.com
Thank In Advance
sale no mobarak !
#24
Posted 23 March 2009 - 06:24 AM
Can u send me on amit.aggr@gmail.com
Thanks in advance
Amit
#25
Posted 24 March 2009 - 03:45 AM
Kindly send me the thumb rules.
My e-mail ID is sanjeev200497@rediffmail.com
Mastered Process EngineeringStarted by Guest_Boudinahh8777_* , 31 Oct 2025 |
Gas Sweetining ProcessStarted by Guest_Alameerha_* , 10 Nov 2025 |
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Any Ways Or Where To Find The Licensor Process?Started by Guest_adrianong_* , 19 Sep 2025 |
