Hi
I have a question on pump dyanmic analysis
Actually my client plant capacity was 230MBD and like to increase the flow from230to 280MBD,
they have a pump at operating capacity 1371m3/hr,
Now I have to check whther the incresed flow can be suitable for the existing pump
how can i do the dynamic analysis in hysys
any comments on the above appreciated
regards
sean
Pump Dynamic Analysis
Started by SeanK, Dec 15 2008 03:15 AM
Posted 15 December 2008 - 03:15 AM
Posted 15 December 2008 - 05:28 AM
QUOTE (SeanK @ Dec 15 2008, 08:15 AM) <{POST_SNAPBACK}>
Hi
regards
sean
regards
sean
Careful using the word dynamic "around" HYSYS - in HYSYS terms, as far as I'm concerned, that means time-varying.
What you want to do is look at the pump characteristic curve, which shows the flowrate that the pump will operate at when it is subjected to different differential pressures. Read off the flowrate that you are going to operate at, and look at the corresponding differential pressure. If you can create that sort of differential pressure across the pump, then you're OK. If it can only supply that sort of flowrate at a LOWER differential pressure, then you have to do some tinkering with your process setpoints, or consider changing your pump.
Hope this helps,
- Steve.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
