How To Get The Latest Cepci
Started by pjadams, Jan 09 2009 10:28 AM
7 replies to this topic
Posted 09 January 2009 - 10:28 AM
Hi Everybody,
I am on an assignment to estimate a pressure vessel cost and I found a spreadsheet to calculate. But the current pricing is dependent upon the CEPCI which is published on "Chemical Engineering" magazine. I went to my library and found a not so up to date issue, so the latest number I got is from Aug. 08, the composite number is 619.3 with Equipment index of 761.
As you all know, the market and oil price has crashed since then and all the commodity prices have been down ever since. This could impact the CEPCI number for sure.
Does any of you have access to the Chem Eng magazine and can you tell me what the latest index number is?
At the mean time, I will take some time off, driving to the local libraries and find out what the latest index number is. If successful I will share with you and discuss various aspects of the equipment pricing.
PJ.
PJ.
Posted 09 January 2009 - 05:19 PM
From CHE magazine Dec. 08 issue, the latest numbers are the following (Sept. 08):
- CE Index is 609
- heat exchangers & tanks index is 744.4
- CE Index is 609
Posted 09 January 2009 - 06:29 PM
QUOTE (sheiko @ Jan 9 2009, 06:19 PM) <{POST_SNAPBACK}>
- CE Index is 609
- CE Index is 609
Thank you very much,
PJ
Posted 10 January 2009 - 03:22 PM
Here I put the new numbers into the complied summary of CEPCI index:
Posted 22 January 2009 - 04:25 PM
the latest numbers are the following (Oct. 08):
- CE Index is 592
- Equipment index is 720
Based on "Chemical Engineering", Jan. 09 issue.
- CE Index is 592
Posted 23 January 2009 - 12:17 AM
QUOTE (pjadams @ Jan 23 2009, 02:25 AM) the latest numbers are the following (Oct. 08):
- CE Index is 592
Dear friend, Thanks for the update(s)indeed.
Qalander
- CE Index is 592
Qalander
Edited by Qalander (Chem), 09 October 2010 - 12:11 AM.
Posted 05 February 2009 - 05:55 PM
i seem to be able to get it for free from their website although the website is a nightmere to navigate
If you sign up (for free) you should be able to get it.
Im using it to correct costings from C&R vol six (mid 2004 to current)
Posted 05 February 2009 - 11:20 PM
QUOTE (Simoncpe @ Feb 5 2009, 05:55 PM) <{POST_SNAPBACK}>
Thank you,
I will check it out.
PJ.
![]() I Need 2020 CepciStarted by Guest_datjohn_* , 02 Nov 2020 |
Chemical Engineering Plant Cost Index (Cepci)Started by Guest_tk117_* , 05 Aug 2022 |
Chemical Engineering Plant Cost Index (Cepci)Started by Guest_A.Shatla_* , 25 Aug 2014 |
![]() Chemical Engineering Plant Cost Index Cepci Of 2016 And 2017 ?Started by Guest_Krish117_* , 30 Jun 2017 |
Engineering Costing Latest ReferenceStarted by Guest_kangas_* , 22 Jun 2021 |
