In HYSYS there are some sample case already installed.
How can I change parameters (say in amine package) to run the program.
As a beignner please help me.
Regards.
Sample In Hysys
Started by aanita, Jan 15 2009 01:08 AM
Posted 15 January 2009 - 01:08 AM
Posted 15 January 2009 - 05:34 AM
Which parameters you are referring to ?
Are you intended to change the thermodynamic package ? If so, enter BASIS ENVIRONMENT.
Posted 15 January 2009 - 01:00 PM
Operating parameters like:pressure, temperature, composition of different feed streams.
Posted 15 January 2009 - 03:56 PM
Anita,
I think you need someone to guide you through basic operations in HYSYS, so you could become familiar with software environment. It's difficult to do this by posting replies on ChE forum.
Good thing is if you could start with HYSYS manuals, and have an experienced person somewhere by your side to ask him a question whenever you stuck with model setup and development. This is the fastest way to learn things.
Good luck,
Good luck,
Posted 16 January 2009 - 01:49 AM
I would strongly recommend you to goes through the HYSYS manual (GET STARTED). You may find plenty of HYSYS manuals available for download as listed in "Useful Documentation for HYSYS ..."
